Weird GPS problem
Hi you all!
I've have a apm 1 board with gps connected.
When i connect my board via usb to mission planner, i can receive gps signal.
but when i'm using my xbee, everything works exept my gps signal! if i then connect my usb to my computer, then its working over my xbee...
So i think its a power issue, when powered over usb, its working, when powering over ESC it's not working.
Can someone help me?
Thank you guys!
  • Hi,
    I am having the same trouble...did you figure out what was wrong? I am powering my APM via the RC receiver, which is supplied with a 6.6V Life battery. As soon as I use the xbees and disconnect the USB, I get "no GPS" indicated on the mission planner, but with the USB, I get GPS lock and everything works perfectly!
    Any advice?
    Duncan
    soound like a power issue. your escs must not be providing enough power.
