First of all, choose an light drone frame is very important.
The load capacity , wheelbase and drone arm diameter of the frame will decide the motors, propellers and battery models.
Therefore, it is necessary to understand the parameters of the frame in advance.
Then prepare the following accessories.
Please make sure weld the plugs of motors, water pump, and FPV camera in advance.
12435085064?profile=RESIZE_710x
If you want to assemble a 10L agricultural spraying drone, and the total weight of the full load is less than the certification requirement of 25kg,
then the E610M frame is an good option. The specifications are as follows:
Frame Specification
Wheelbase
1402mm
Frame (net weight)
3.6kg
Tank (net weight)
835.8g
Effective load
10kg
Expanded size
1472*1284*547mm
Folded size
772*703*592mm
Arm diameter
φ30mm
Optional color
Blue/White
Working temperature
-20-50℃
