When i first running test code the ardupilot(with out connect to gps) was very hot!! .and when i connect to gps 406A the gps is not lock and the servo control by transmitter and turn to a little right ,GPS LED blinking ,mux off ,stat on ,power on was that correct in test code .and also When i connect to gps the the transmitter also can control rudder and i conect the CTRL to the ch1 ,but i toggling ch1 in transmitter but the mux did work in test code .I was not sure about those?
  • Thank you Chris I wil think about it .
    It should not be hot. You've messed something up in your soldering or wiring. Check everything again.
