Has anybody experience with the MPXV7002DP airspeed sensor installed on a skyfun?
In the front it is prone to pickup dirt from landings and will be in the way of the cover closing mechanism.
In the Wing it would require extensive modifications.
What do you recommend?  Do you have a similar setup? What works best?
  • This is the best setup I've seen so far:
    3692424008?profile=originalSource:
    Thttp://www.fpv-community.com/forum/showthread.php?tid=513
  • Monroe,
    Thank you, very interesting. My problem was that I assumed the tube needs to stick straight into the flight direction. If I can mount it at an angle that's easy!
