Hi guys,
Anyone else seen this? It's not a great pic, but I think you can see the white bars corrosponding to the same location as the minimOSD text on the screen. (though this picture makes them look much worse than they are).
3691038182?profile=original
No matter what I do, I can't get the bars to fade away; only if I tune contract and brightness to zero, does it look ok, but then everything else is black! The OSD is set to minimum brightness, but makes no difference.
Did anyone else have this issue, and how did you solve it?
My setup:
Atitude SD's + 5.8 bluebeam. Powered by 2S
Fatshark 250mw 5.8 + bluebeam. Powered from filter box using 3S
GoPro2 connect via media cable. Powered internally.
Setup is PAL not NTSC.
Is there anywhere to really crank the OSD brightness down? Image is fine without it. OSD also running fine - it's just smearing white horizontally on the screen wherever it places text.
  • Hi guys,
    I've tried to demonstrate the problem a bit better using a slide to show the "smudging". Ie the image is clear, the text is clear, but the text introduces a vertical screen-wide smear behind. The OSD data is correct and updating ok.
    3692770847?profile=original
    I've also included my diagram. Can anyone see any faults with this? The two sides of the minim are not joined, but it all runs ok.
    3692770551?profile=original
