I would like to ask if someone can give me advice what I'm doing wrong when APM won't log me anything. In the CLI I first erased all logs and then enabled them by command enable all. After flight (around 15 minutes, GPS and APM had home locked) CLI told me that there are no logs available.
Must be there some event that starts logging? Or in general when the logging starts?
Did you use the erase command first?
