    Hello Will,
    I have flown the ArduCopter in winds of about 15 mph with gusts up to 20 mph, it can be a little hard to control, so if you are happy with a little excitement in your flights...... :).
    However it was fine with the power it could put out to flight into the wind, I have never used the x configuration just the +.
    My quad is running the stock 850Kv motors and 10" props. There is a video here where the winds were a little lower when one of my customers and I were out testing our copters, the conditions were far from idea!
    I hope this help you also.
    Regards
    Martin.
    www.buildyourowndrone.co.uk
  • im new here too... but i think i can give you an answer:
    it all depends on the design you use, and im not sure but i dont think x or + will make much of a difference. i would think a heavier and more powerful quad would do better. good sensors would probably help too
