Dear lovely people,
I am wanting to find a camera and wireless transmission system that I can use to track moving objects on the ground from a quadcopter. The image data will be analysed on a computer in OpenCV.
Like this: https://www.youtube.com/watch?v=v9KjAdvPF0o
Signal latency must be kept to a bare minimum and a frame rate of at least 30FPS is also needed. Also the higher the image resolution the better. I am debating between digital vs analog transmission.
Anyone done anything like this before? Or can recommend suitable cameras and wireless transmission technology that can interface with a computer?
Many thanks!
    Yes, we already support wireless camera and OpenCV, running either onboard on an Odroid board or on the ground. See this post for more.
    • Thanks for the reply Chris!
      I read that post, but I still have questions about the best way to get data quickly to a computer on the ground. I want to do it digitally if possible but I think high latency is going to get in the way. Still searching for a camera and transmission system that will work. Once the images arrives at the computer I have no worries manipulating the data.
      • Hi Jesse,
        Just wondering. Have you figured out based on your experience of any reliable wireless video transmission with reasonable cost which can be used for processing (e.g. opencv) later? I find normal ip camera quite laggy due to its latency.
