My Skywalker setup was working fine until I changed my Radio and RX.
After change, I reset everything and calibrated radio.
Now,
with airspeed sensor attached and turned on, aircraft pitches down when switched to RTL,
in same position, I disable airspeed sensor, when switched to RTL, plane tries to climb loitering altitude normally, perfect.
Is my sensor damaged?
When I plug in sensor and enable it and blow it to test, everything is accurate. But plane pitches down.
Please help.
Regards.
when uploading firmware with apm 1.0.82 and before, it works.
