Wobling hexa
I just finished the arduhexa with "standard" configuration (MK hexa frame, 28-30 1000kv RC-Timer, 30AESC RC-Timer, 10x4,5 props, AC2 2.0.49 defalut config.
All works quite ok, but machinery wobling... but not about it. I tryed to change the PID's in APM Planner,  last wersion. I can change the STABILIZE ROLL and STABILIZE PITCH but if Im trying to change any otcher value, the program keeps displaying "SET_RATE_PIT Failed" (PIT, ROLL, etc). Any idea what is going on...?
I mention, that all hardware seting are properly set and connection is fine.
By the way, maby open the separate discussion where we can share our successfull PID's...
Regards
    This version of the mission planner requires your switch to be in CLI mode to change those params. That;s a bug that will be fixed in the next revision.
    Jason
