Xbee Telemetry enabled?
I've just upgraded from Ardupirates NG to AC2 2.0.30.
Setup via USB was simple enough.
When I plugged in my Xbee to my PC, set the baud to 57600, I just get garbage on the terminal.  Tried changing baud.
Mission planner doesn't connect via Xbee.  I'm using the same Xbees as from Ardupirates.  Telemetry was working ok on Ardupirates NG
I can't find where to enable/disable telemetry, so is there something that I'm missing?
    Hai, telemetry is now using the binary MAVLink protocol. You won't be able to read it in a terminal.
    When you tried to connect via the Mission Planner, did you change the baud rate to 57600?
