Xbee will not work with latest Arducopter code
Try as I may, I cannot get my XBee Pro modules to work with Arducopter and Configurator, I have read through and tried the solutions offered by other on the site but to no avail.
Does the latest version of Arducopter code work with configurator over XBee link ?
  • I have two XBee 900MHz units working fine here, including Configurator. It's not terribly useful, but it does work.
    I left the baud rate at 115200, set both XBees to 115200, and #define IsXBee.  That's pretty much it.
    I did test out the XBees with two adapters, loopback, and some experiments.  They worked fine talking to each other before I started.
  • Hi Sebastian,
    Yes i did uncomment "#define IsXBee" under ArducopterNG tab.
    I have 2 pairs of adapters, (1 pair of the Adafruit adapters from sparkfun) and  (1 pair of the diydrones adapters with the master/slave switch)
    I did try the link back test and it worked fine.
    I have also run the 2 Xbee modules between 2 pc's and I am able to send and receive data no problem.
    I don't know what else to try, I have read the previous posts on this issue and tried the various options, but still can't seem to get it to work.
    The XBee modules I am using are the XBee Pro 60mw modules form Sparkfun.
    Regards
    Rob
