3D printed truck
8910822072?profile=RESIZE_710x
8910913878?profile=RESIZE_710x
The high cost of good RC truck kits, diminishing need for such kits & the noise of gearboxes made me look elsewhere for a robot platform.  3D printing a truck from scratch, with only a few metal parts still being off the shelf, was the next step.  The only parts which have to be outsourced are the motors, steering servo, & steering knuckles.  Everything else is 3D printed or home made electronicals.  The size was based on the original Tamiya lunchbox.
8910820663?profile=RESIZE_710x
8910862088?profile=RESIZE_710x
8910842477?profile=RESIZE_710x
8910853293?profile=RESIZE_710x
The remote control is a single paw 3 channel, with 100mW radio, ball point pen springs, hall effect sensors.
8910905662?profile=RESIZE_710x
8910905683?profile=RESIZE_710x
The remote control is charged inductively.
8910864885?profile=RESIZE_710x
8910868496?profile=RESIZE_710x
Motors are direct drive Propdrive 4248's of any KV rewound with 20 turns of 26AWG.   They don't produce enough torque to go up hills.  The motor sensor is a dual hall effect sensor resolver.
The main problem is cooling the motors while getting more torque.  Metal motor mounts of the right shape continue to be cost prohibitive & PLA doesn't dissipate heat.
8910880482?profile=RESIZE_710x
8910880691?profile=RESIZE_710x
Electronicals automate just enough to drive it with 1 paw, but not so much that it's never finished.
8910883454?profile=RESIZE_710x
8910883474?profile=RESIZE_710x
8910883694?profile=RESIZE_710x
8910886053?profile=RESIZE_710x
8910886455?profile=RESIZE_710x
Traction & steering are 2 separate modules.  Steering uses a brushless servo with stock lunchbox servo saver.
8910884879?profile=RESIZE_710x
Motors are powered by L6234's mounted dead bug style to get the heat out.
8910890092?profile=RESIZE_710x
8910890477?profile=RESIZE_710x
Tires are printed out of TPU in varying shapes to adjust hardness & traction.
8910891284?profile=RESIZE_710x
8910895474?profile=RESIZE_710x
Rear tires have a flat wide shape for more forwards traction.  Front tires have a round shape for more sideways traction.
8910909092?profile=RESIZE_710x
The battery is completely enclosed.
