3D Printing an ArduCopter frame
3689420252?profile=originalArduCopter user Octivir broke his original frame, so he decided to build a new one using carbon fiber arrows from a department store and 3D printed parts, which has now posted to Thingiverse:
So I purchased an Arducopter Pre-assembled and tested, Something I rarely do. Maybe it was a subconscious action then, that within a week I had smashed it into the ground?
Now I am designing and rebuilding it, testing and learning and really enjoying it.
Some pieces survived and I had initially thought to design things as a replacement/upgrade. Now I think that would be silly to tell people to "Print these, and buy these 'special' parts", so I am making the attempt to make this frame fully DIY...
I haven't really been documenting the process, but initially it seemed there would be a slight weight savings in the carbon fiber/ABS parts vs the stock arducopter aluminum/acrylic parts.
Maybe some different construction methods could be used to increase savings?
This is very much a work in progress, but thought I'd get the idea out in order get some feedback and enable collaboration.
Instructions
The goal:
Get some carbon fiber shafts.. Got mine at walmart for $3 a shaft(29 inch, ~8mm dia. arrow shafts), I estimate it will take 6-8 of these, depending on desired frame size..
Print parts.
Use 3mm hardware to assemble nuts and bolts
(Via the MakerBot blog)
  • Thanks so much for posting this Chris! I've been thinking of building a design that was completely 3D printed. I never even considered carbon fiber arrows though. Now the wheels are turning... lol. In addition to being strong and light-weight, the ends are also threaded, making the design even easier to implement.
    would this work at Ponoko? how strong is the 3D printing? ... that sounds a great alternative...
