Hey everyone, it always bothered me when my Quad hit the ground hard, so I started looking on a way to add a suspension to it and after 2 weeks of trying, this is what I came up with:
I got some shock absorbing from a 1/10 scale buggy and added wheels, one on each side of each leg with a total of 8, they are very light (used on some airplanes like Apprentice etc). Had to 3D print some parts to hold the shocks on the Arm, I also printed the Sonar support. I am very happy with the result of the suspension. To test it I cut the power off at about 2 feet high and it hit the ground but it doesn't bounce at all (the shocks absorb all the impact). I'm very satisfied with the results, and I just wanted to share.
Comment by John Church on April 15, 2012 at 6:38pm
Heh-heh. My co-hobbyists call these "Navy landings"... I'm a pro at them.  ;)
Very nice solution! Very rugged.
Comment by Ellison Chan on April 15, 2012 at 6:45pm
Nice.  Love to see some video of it in action.
Comment by Chris Anderson on April 15, 2012 at 7:18pm
Cool! How much weight do they add?
Comment by Luiz Miranda on April 15, 2012 at 7:38pm
they only added 100 grams
Comment by SKYracer on April 15, 2012 at 8:35pm
Luis, me puedes dar las dimensiones de tu quad?. que helices estás usando? Tengo unos motores idénticos y quiero aprovechar tu experiencia
Comment by SKYracer on April 15, 2012 at 8:38pm
Luis, can you give me the dimensions of your quad?. what props are you using? I have some identical motors and want to take your experience. Thanks
Comment by John Hestness on April 15, 2012 at 8:47pm
I like your design a lot.  Did you find some light weight shocks?  Or modify them for lightness?  How expensive was everything?  What is the size and weight of your quad?  I think somebody could sell a kit like this.
The picture is of a crazy large prototype nose gear I built also using 1/10 scale shock (from a slash) it was going to go on a large drone.
Comment by Luiz Miranda on April 16, 2012 at 5:48am
Hi skyracer, my Quad is the 3DR bought the kit here at DIY Store, as far as dimension I measured 24" from center of the motors on diagonal, I have project that I downloaded, if you want it I can email to you. For my props, I use the 12x4.5 made in Germany, found it to be much better and more resistant also, I buy them from this website (http://www.innov8tivedesigns.com/product_info.php?products_id=994)
Comment by Luiz Miranda on April 16, 2012 at 6:07am
John, I used a stock shock (19g each) , the wheels are only 3g each, as far as price, I spent about $50.00 because I had to buy 4 rear (Apprentice) suspension to get the wheels etc, If we can find the source to buy just the wheels I am sure it would be lot cheaper. I did not weight the entire Quad, but the suspension only added about 100-120grams.
Like your design too, looks really good
Comment by Ellison Chan on April 16, 2012 at 8:29am
I think the 100 grams is a little too high., though It's almost the weight of a GoPro camera.
Maybe you should use wheels made specifically for aircraft, like this:
Comment
