Takeoff weight was 2160 g, 4S 6000mAh, 8 minutes in the air.
I closed the GPS and open SONAR. Set CH7 switch AutoTune.
First, Stabilize mode and height 10 meters remain, Then, Change the flight mode to ALT HOLD
I open AutoTune, any did not happen.
I closed AutoTune, Plane began "dancing" and I got a new PID at three minutes later.
I checked found, Remote control is set incorrectly, CH7 switch is reversed.
I use 3DR Y6A, including
3DR Y6 Frame + Electronics Kit (2013 Version)
3DR Pixhawk
Telemetry Radios 915 MHz
3DR uBlox GPS with Compass Kit
APM MinimOSD Rev. 1.1 Kit
and
APM Power Module with XT60 Connectors
PX4FLOW KIT
MB1240 XL-MaxSonar
For more information :
http://diydrones.com/profiles/blogs/first-flight-3dr-y6-to-bear-my-...
Many Cables are not included in this package
There are six motor and six ESC, which has three motors, three ESC, and two Propellers are disabled.
I re-purchase and replacement
Time and again, eventually took 129 days to complete the installation
Prepare for the first flight
- Balance Motors and Propellers
- Using default parameters Y6A
- Use FUTABA T8J, R2008SB and PPM Encoder
- SONAR connection Pixhawk ADC 6.6v
- Finally, use the Mission Planner, and in the "Options CH7" as "AutoTune"
The default PID
PID AutoTune after
Now 3DR Y6 flight was not my needs, some of the recommended products are not supported, the beginning of the design of many changes.
Despite this, I still hope that it will appear in my documentary - A beautiful drone flying over the Amazon.
How are the new PID's? And which version of the Y6 is this - A or B? It looks like you have bigger props on the bottom, so is it an A?
How are you finding the Sonar?
Some nice pictures here btw.
