The aim of a good UAV is to have a fall-back system by which a human pilot can take over if (when!) the autopilot goes funky. There are at least three ways to do this, all of which we feature in one or more of the autopilots here:
- Completely separate the navigation and stabilization systems and ensure that the stabilization system can be overridden by manual RC control. That's what we do in GeoCrawlers 1, 2 and 3, all of which use the FMA Co-Pilot for stabalization (it controls the ailerons and elevator, leaving just the rudder for the autopilot and navigation). If the autopilot crashes, you can still fly the plane with ailerons and elevator alone, something we end up doing all too often! (The FMA system always allows for manual input)
- Mechanically separate the autopilot and RC control systems. In the case of the Lego UAV ("GeoCrawler1"), the Lego Mindstorm system moves the whole rudder servo back and forth, but the RC system can always turn the rudder servo arm, allowing it to override the autopilot if need be.
- Install a stand-alone "MUX" or servo multiplexer, that allows the operator to switch control from the RC system to the autopilot and back again with the gear switch on the transmitter, even if the autopilot catastrophically fails. As far as I know, there's only one commercially available one of these out there, and that one, by Reactive Technologies (shown), is not cheap ($99). Still, if you install one and give it an independent power supply, there should be no reason why you can't regain control of your plane no matter how wonky your onboard computer has gone.
So the Basic Stamp UAV project might be a good place for a MUX. Anybody know of a cheaper one? (This guy is looking for one, too)
Only!!! No idea how to do that...
http://jordii07.googlepages.com/AutoPilot2cores.jpg
Using two Arduino (dual core) to divide the work. The red, yellow and black boxes are totally separated (independent power). The channel 5 is a servo connected (clip) to a mechanical switch to select between manual mode or auto mode, if some think goes wrong with Arduinos you always going to have the control.
So you could have 2 controllers. Controller 1 takes input from the radio, gps, sensors, etc., does the math, and produces an output signal. Controller 2 also takes pwm signals from the radio and additionally from controller 1's processed output, and it chooses the appropriate source to output to the motors.
The code in the switching controller is very simple, and you go over it with a fine tooth comb and prove its validity. Then you can experiment with your code in the flight controller all you like and not have to worry about something catastrophic happening.
http://www.rcgroups.com/forums/showthread.php?t=801709
Let me know if there's anything I can do to help.
