The aim of a good UAV is to have a fall-back system by which a human pilot can take over if (when!) the autopilot goes funky. There are at least three ways to do this, all of which we feature in one or more of the autopilots here:
- Completely separate the navigation and stabilization systems and ensure that the stabilization system can be overridden by manual RC control. That's what we do in GeoCrawlers 1, 2 and 3, all of which use the FMA Co-Pilot for stabalization (it controls the ailerons and elevator, leaving just the rudder for the autopilot and navigation). If the autopilot crashes, you can still fly the plane with ailerons and elevator alone, something we end up doing all too often! (The FMA system always allows for manual input)
- Mechanically separate the autopilot and RC control systems. In the case of the Lego UAV ("GeoCrawler1"), the Lego Mindstorm system moves the whole rudder servo back and forth, but the RC system can always turn the rudder servo arm, allowing it to override the autopilot if need be.
- Install a stand-alone "MUX" or servo multiplexer, that allows the operator to switch control from the RC system to the autopilot and back again with the gear switch on the transmitter, even if the autopilot catastrophically fails. As far as I know, there's only one commercially available one of these out there, and that one, by Reactive Technologies (shown), is not cheap ($99). Still, if you install one and give it an independent power supply, there should be no reason why you can't regain control of your plane no matter how wonky your onboard computer has gone.
So the Basic Stamp UAV project might be a good place for a MUX. Anybody know of a cheaper one? (This guy is looking for one, too)
Thanks! I am no longer with the research company that I was working for at the time I designed the board, however while I was there, we fabbed 45 boards (but only a subset of those were populated with components). I will enquire if any of those are still available for purchase. I'm sure they wouldn't mind selling the PCBs themselves (blank, unpopulated), but, as I understand, they don't really have the capacity to do assembly work. If the assembly (populating the board with the components) were out-sourced the price might rise considerably.
Can you please post a link to the RCGroups discussion. If I can establish an approximate number of interested people, I might be able to arrange production myself.
First, great to hear from you: I'm a fan! (watched your presentation, been following the project),
Second, what a great board! I posted about it on RCGroups and people were wondering how to get it. I assume the answer is "DIY", but if you know of any way to buy finished boards I'd love to pass it on. If not, would you have any objection to us fabbing a stack of them and selling them for cost?
Nope, it would work exactly the same as a 2-axis accelerometer with a really low bandwidth (due to the inertia of the mechanical ball) and low resolution/quantization. And as you probably know, an accelerometer-only IMU is very limited.
You could emulate it with a cheap 2-axis accelerometer, low-pass filter the outputs, and quantize with a 1-bit ADC (i.e. a comparator).
The hardware is also capable of many other things that haven't been implemented in firmware, like MiniSSC-II servo controller emulation (through the built in serial port), servo logging (there is onboard flash memory), etc
Also of note: the failsafe code is implemented in hardware (in a Xilinx CPLD) to eliminate the possibility of a software crash rendering the plane uncontrollable. That means that, although the switch contains a microcontroller running software, this is used for ancillary purposes and the core switching has no software in the loop that could crash.
