3689663498?profile=original
Hi all,
We would like to share with you our company "droning" (www.droning.es) devoted to create and operate professional UAVs.
Our team has been around diydrones for some years now and we all share our passion for drones and APM.
Some of us started with APM 1.0 or with ArduIMU.
We have focused our efforts on creating quality turn key products that incorporate all our experience in the Multirotor/Planes operation. We have been providing survey services for more than a year now and we have some ideas about how a good platform should look alike:
  • Robust and easy to operate
  • Long flight time (obvious, I know)
  • Easy (and quick) to fold and transport
  • Integrated electronics and modular design
  • No cables or protruding parts -> fairing
Multirotor DE820
With these requirements in mind we started to design a Multirotor (DE820) that could be able to be configured both in Quad and Octo coaxial mode. This way it could be used for Endurance missions on surveys but also for filming and high payload missions.
3689663690?profile=original
We ended by choosing umbrella folding arm design and single-point fixed landing gears as they offer a great stability in rough terrain where it is supposed to operate.
In the Quad version we have:
  • 18 to 20" T-Motor carbon props
  • Tattu 22Ah 6S
  • Pixhawk
  • more than 30 minutes of operational flight
In the Octo coaxial we have
  • 16" t-Motor carbon prop
  • Tattu 22Ah 6S
  • Pixhawk
  • 25 minutes of operational flight
We have created custom PCB to integrate ESC and basic signal routing so we simplify the manufacturing process.
In the next revision we are using Dropix v2 as it will allow us to mount it in a PCB socket and simplify it even more.
3689663775?profile=original
3689663812?profile=original
The DE820 can be configured with quick release payload holder, allowomg to reconfigure it quickly by swaping assembled gimbals with cameras or even connecting an EPM gripper without cabling or screws intervention.
You can find more pictures, information and videos on the web.
TA2000 Plane
Even if the DE820 is our more loved product we do have a Fixed Wing based upon the Talon airframe. We called itTA2000 and it has passed thru a customization process quite intensive.
3689663797?profile=original
We added a front motor mount as we think it flies much better and allow for easier hand launch.
3689663836?profile=original
With its current configuration it weights 2kg with camera on board and batteries. Regarding flight time it can go up to 1 hour at 50km/h.
We are working in extending the range close to 2 hours by using Li-Ion mixed battery.
Hope you like it.
Jesus, Anderl
  • Great work, Jesus and droning people ¡¡.
    We could see and fly the DE850, is a very nice piece of engineer, fully integrated and easy to operate and transport, the flightcase is a very small trolley.
    I flew the DE850 in octo setup with tetracam mini-mca, my feeling was that is very stable and the GPS work fantastic, in automatic mission (with take off, photogrammetric plan and landing) the landing point was reached with accuracy 40-50cm.
    Finally we analyzed the log and the vibrations leves was incredibly low.
  • Thank you all.
    Stay tuned as RTK, quick removable payload system and longer flight time version is coming in the following months.
  • Jesús.El drone is an impeccable job, it is also a very robust design, while agradable.Apoyo his comment that the target to beat is increasing flight time, keeping the size of their dron.Saludos and good luck with your business .
  • @all
    Thanks for the good comments!
    @ravi
    We are currently working in a 45 min version. The key point that we are trying to achieve in that version is the ability to go to that flight time without increasing size nor weight.
    1 hour multirotors are no new but doing so while retaining a small size and weight is a big plus. At the end of the day operation and transport of a big 20kg multirotor is a real pain.
  • can u provide endurance upto 60 mins with 300 gram of gimbal/camera payload.
  • Very cool... I like the X8.. Great work and good luck in you business.
  • Looking good Jesus!
    I like the PCB especially :-)
  • MR60
    Congrats! Looks beautiful. I like the intégration.
  • Thanks Luke. Its been (and continue being) a lot of work.
  • Well done, Jesus!
