Q: In a nutshell, what's the AttoPilot project about?
I was SHOCKED that the cheapest unit that met my basic requirements costs $900 (the UNAV NAT). Everything I found was either really heavy/expensive, or home-made looking. I knew there was much room to improve, even for somebody like me with no idea (at the time) how to make something like an autopilot that I would let fly my airplane.
So, I started out only with ideas of how it "should" work with no ideas of what roadblocks the hardware/coding might have in store for me. I think this naiveness was an asset. Features of initial release hardware rev (other versions coming, some smaller):
- Small size: Atto is a single package of about 25x20x10mm with right-angle header connections to the servos, like a small 6 channel Rx. The only external pieces are the GPS module and CoPilot sensor head.
- Rx interface: Atto reads the channels from your Rx through the servo jacks, no soldering to the Rx board. Atto is designed to read 3V/5V logic signals automatically, and ANY pulse order from the Rx, be it overlapping or serial, Atto doesn't care. It reads with precision to < 1us.
- Integrated data logging to micro SD card, and USB jack for interface to your PC. Currently in testing, I have about 20 parameters logged at user-configured sampling rate, up to 5 Hz. You can view the flight history in Google Earth as a 3D path, plus analyze many details of the flight, including how the autopilot performed, and what it was "thinking" at the time. You can use this data to know precise location of aerial photos.
- 100,000 waypoints that are 3D. Make your flight plan graphically in Google Earth, then use simple formatting application in Windows to hand-edit the path, and add XOR checksum to each line. The finished file goes on the SD card via USB jack.
- No limit to distance between waypoints, or to how far the unit can fly from starting point. Proven to work in all hemispheres (NS, and EW of the prime meridian)
- Intergrated static and dynamic barometers with special data filtering routines, for baromteric altitude control (that is corss-referenced against GPS altitude) and pitot tube airspeed.
- Currently 8 triggerable events at each waypoint. User-configurability what the 8 events are, be it position of auxillary servos, etc... Useful for Aerial Photography.
- Drives up to 6 servos, with user-configured mixing of servo outputs (for V-tail, elevons, or even just 2 seperate aileron servos)
- Telemetry jack to the XTend modem by Maxstream. This is currently being developed but is on track. Working now is the downlink to moving map software, but goal is 2-way com to take R/C control at long range, upload new waypoints, and issue commands such as RTL.
- Stability/attitude control: FMA's CoPilot thermopile head is used in a special way: By fusion of the thermopile data with barometer and GPS data, a very robust and self optimizing system is created. Auto trimming during flight, auto gain adjustment.
Schedule of availability: Summer 2008. Beta testing is still going strong with rapid roll-outs of firmware upgrades, and hardware add-on PCBs that will be integrated into final production version.
Q: What's the origin of the name "AttoPilot"?
Well, you have micro and pico pilots, and they refer to the SI notation for millionth and trillionth (1x10e-6 and 1x10e-12), respectively. I have talked to Curt Olson off and on, so I know that guys like him don't need the tiniest autopilot, but for people that do, I'll offer something smaller than the "pico" pilot. "Atto" is SI notation for 1x10e-18, or a millionth of a trillionth. Also, Atto is like Auto, so instead of an auto-pilot, you get the name Atto-Pilot!
BTW, the Beta Attopilot uses pretty big DIP processor and breakout boards from sparkfun.com, but even
then with GPS the unit comes in at 1.6 ounces, which is already HALF of the Pico
Pilot's assembly of PCBs to make their complete system. By going to a NEWER GPS
besides the ETek unit and having Atto be a 100% SMD [surface mount device], the mass drops down to the
figures I quoted, in the < 1 ounce range.
In addition, I have a 6 gram "shrink" version with integrated Kalman IMU on the same PCB with integrated GPS and antenna and
other sensors. This version is suitable to fit INSIDE the wing of a tiny
MAV (like a 6" span plane). This is a work in progress, but I suppose
my point is that my autopilots will TRULY be Atto in sized over this coming
year.
[You can read more about this project and its inception in these two RCGroups threads. Latest beta details. The origin of the project emerged in this thread]
[Part 1 of the interview is here. Part 3 is here.]
You bring up a funny point that highlights my motivation. If all I wanted was to get an airplane autonomous, it would have been far cheaper to just buy a commercial system, even a $5k+ system like micropilot. But, I like to design and build things and figure them out much more than I like to just use pre-bought things.
Plus you can take a tax write-off on all your toys!
In the end, I will be able to sell it at a lower price (and more features) than any other ready to go commercial unit, chiefly because of personal expenditure of time.
