After a few more tests, I now have the final version of the ArduIMU. The main problem was the calibration of the gyros: converting the raw data to degrees/s. I had to change the source code, compile it, upload, and repeat it over and over again. Totally waste of time.So i configured Arduino to externally adjust the gyros and the accelerometer jitter filter, using the nunchuck potentiometers (joystick axis). Now it’s working pretty well. =)Please, in the source code, ignore all the lines marked with "//(kalman)", this lines are related to the kalman filter code, those marked by "//(nunchuck) are related to nunchuck accelerometer and axis control, and all marked by "//(gyro)" are code related to the control of the gyroscope.Another tip, all the data is processed in radians, then is converted to degrees (radian*180/PI = radians*57.295779= degrees). If somebody needs any help, please feel free of asking me.Video:-Yellow color = Just Accelerometer read-Red color= Accelerometer+Gyro+KalmanFIiterArduino Source Code: http://sites.google.com/site/jordiuavs/Home/kalman_filter_by_Jordi.txt Labview (ground station) source code: http://sites.google.com/site/jordiuavs/Home/kalman_filter_by_Jordi.txt To do: -Integrate another Gyro (to make it dual axis) . -Program the SPI altimeter.-And put all the hardware together and make it work (GPS, Altimeter, IMU, Modem).
Done: -Servo control -Gps Waypoint navigation (I’ll post later about it).
The next article I'm going to post all the links to get started with Arduino environment. All you would need to learn: tutorials, examples, references, tips and tricks. If you already know C++ it’s going to be 99% easier. If not, you are going to discover why C/C++ is the most compressive and famous language ever ;-) Then jumping to any AVR, ARM, PIC microcontroller C/C++ language environment, is going to be a lot easier, because they’re all based on the same principles.
Thank you very much for your code, but I still have something don't understand.
I have a board that has both accelerometer(ADXL330) and gyro(ENC-03) in it. Is the function analogRead(inputPin); used to get the gyro value from ADC? Is the function print() used to get the value from accelerometer?
What is that unit of the value read from analogRead()? Is it MV?
ZhangZQ
1324
1374
2261
1930
1444
1086
0427
0087
1107
2997
0102
2997
0093
2997
1250
0084
2997
0752
0090
2997
0099
2997
0099
2997
0096
2997
0087
0357
2997
0093
0480
1359
2405
1403
1054
how Can I use that Kalman() get the angle value?
I can not access http://jordii07.googlepages.com/ArduIMUFinal.txt, maybe it is blocked by ISP here, can you email me that article? thank you very much!
my email: zhangzq71@hotmail.com
thank you very very much from Italy.
Maybe you can take advantage of what I found out and did so far ... (of course with credits to all the people i use code of.)
I am going the "library" and function approach.
And the Heli i got is cheap and reliable for this :-)
Thank you so much ... I try to figure this out now.
Currently my only plan is to provide nick/roll stabilization (my 4 year old son wants to fly my heli :-))
and the gear is stabilized by a AVCS (Angular Velocity Control System) gyro anyway. And therefore i just want to use the Kalman filter for nick and roll "denoising".
angle_m= arcTan(axisX,AxisZ);
X= is for the pitch
Y=For the roll
Depends in the way you positioned your accel..
