Final version of ArduIMU (Include Video)
After a few more tests, I now have the final version of the ArduIMU. The main problem was the calibration of the gyros: converting the raw data to degrees/s. I had to change the source code, compile it, upload, and repeat it over and over again. Totally waste of time.So i configured Arduino to externally adjust the gyros and the accelerometer jitter filter, using the nunchuck potentiometers (joystick axis). Now it’s working pretty well. =)Please, in the source code, ignore all the lines marked with "//(kalman)", this lines are related to the kalman filter code, those marked by "//(nunchuck) are related to nunchuck accelerometer and axis control, and all marked by "//(gyro)" are code related to the control of the gyroscope.Another tip, all the data is processed in radians, then is converted to degrees (radian*180/PI = radians*57.295779= degrees). If somebody needs any help, please feel free of asking me.Video:-Yellow color = Just Accelerometer read-Red color= Accelerometer+Gyro+KalmanFIiter
Arduino Source Code: http://sites.google.com/site/jordiuavs/Home/kalman_filter_by_Jordi.txt Labview (ground station) source code: http://sites.google.com/site/jordiuavs/Home/kalman_filter_by_Jordi.txt
To do: -Integrate another Gyro (to make it dual axis) . -Program the SPI altimeter.-And put all the hardware together and make it work (GPS, Altimeter, IMU, Modem).
Done: -Servo control -Gps Waypoint navigation (I’ll post later about it).
The next article I'm going to post all the links to get started with Arduino environment. All you would need to learn: tutorials, examples, references, tips and tricks. If you already know C++ it’s going to be 99% easier. If not, you are going to discover why C/C++ is the most compressive and famous language ever ;-) Then jumping to any AVR, ARM, PIC microcontroller C/C++ language environment, is going to be a lot easier, because they’re all based on the same principles.
  • Jordi,
    Congratulations for this project!
    But the link (http://jordii07.googlepages.com/ArduIMUFinal.txt) is not work... Could you send me?
    Thank you.
    Erick Netto.
  • Jordi,
    Thanks for the great job
    Please let us have a link to the Labview code
    greetings from Grenoble, France
    yves
  • Jordi,
    Your Kalman implementation looks to be identical to tilt.c…so…
    How do you solve lateral acceleration? In an aircraft z may remain constant (coordinated turn) and y or x may change proportionally when skidding (lateral acceleration) or forward acceleration or decleration. 5DOF+K-filter interprets lateral acceleration as pitch up/down (climbing, diving) or skidding )(roll in opposite direction of skid).
    Paul Mace
  • jordi,
    what can i say... kudos to you... thx for the wonderful job...
  • Hi Jordi!
    Great work i must say!
    Im wondering if your are doing some progress on your "Kalman Function"?
    Im really intrested in your work! Im building a Quad enginge heli, with arduino and 5dof, 12bit ADC and other things, but im stuck on the Kalman filter thingy. Can you please help me?
    Regards Niklas from Sweden
  • Thanks a lot Jordi. It really is a big help to getting started with this stuff. Do you still have the Labview code? I only see the arduino sketch on the new site.
    Sorry my last email was hack so i lost all my links, this is the new source of the filter, i thnk better explained:
  • Jordi (or for that matter, anyone else who might have the files), could you repost the arduino and labview code? It seems the googlepage they were hosted on has been shut down.
  • Well done, jordi.
    I am very interesting on this project and I am trying to build an imu on my own.
    I can't dwnload the file, http://jordii07.googlepages.com/ArduIMUFinal.txt.
    Could you mind sending me an email with it? Thx.
    My email: dongyiyuan@gmail.com
  • Hi im wondering if i can get the Imu final.txt aswell.. the link is broken..
    thnx
