Posted by Chris Anderson on February 15, 2008 at 11:00pm
We've forked the Blimp UAV into two projects, a minimum and a maximum one. The maximum one is the one that's using the NorthStar "synthetic GPS" directional system and all sorts of other goodies to be a real indoor UAV, with full room sense and navigation ability. That's moving ahead really well, and I hope to have PCBs and code to show you soon. But we also wanted to create a "minimum" blimp UAV that was the cheapest, simplest robotic blimp possible.
Here's what the Minimum Blimp UAV consists of:
* A BlubberBot envelope and dual thruster motors and mounts (we cannibalized a few other bits from this kit, such as the battery holder and voltage regulator).
* A pair of Pololu IR transceivers (one a beacon on the ground, the other onboard)
* A third motor for vertical control
* A Parallax Ping))) ultrasonic sensor for altitude sensing.
* A Boarduino board with ATMega168 chip (Arduino clone).
* Two Pololu twin motor driver microboards
All that this Blimp UAV is designed to do is to maintain a constant altitude and navigate around a stationary IR beacon on the ground (it just heads towards the beacon, overshoots, turns around and heads back at it). But that's the beginnings of real autonomy!
Target price: <$100 (we're not there yet).
Here's a video that shows how the Pololu IR transceivers work (and here's some BS2 code to test them):
That sounds very similar to the Ping))) ultrasonic sensor we're already using. What's do you see as the main advantage? (We use the ultrasonic sensor for altitude control, and are never more than 5 ft off the ground)
I just found your site and need to spend some time becoming familiar with it. This ultrasound sensor doesn't fit this projects budget, but I feel that it is valuable to know about it in case you want accurate object sensing.
Hopefully, this is not too off topic
LV-MaxSonar-EZ1 which would give you an (serial) RS-232 interface for about $25. It is capable of detecting an object within the range of 0 inches to about 21 feet with a resolution of +/- one inch. There is a datasheet here. www.maxbotix.com/uploads/LV-MaxSonar-EZ1-Datasheet.pdf
Thanks for the link, which I hadn't seen. They seem to use mostly video for target spotting and navigation, which really brings the cost and complexity up (but is, of course, ultimately a more flexible solution). I'll post more on that later today.
The range we get on those Pololu sensors is about ten feet in a sun-filled room. Maybe at night and under artifical light that would be 1.5x that. It's not super long either way.
The minimum blimp will be used for a high school aerial robotics competition, correct? Have you thought about any specific details in regards to that (i.e., what objectives, etc).
It's a shame I won't be able to compete in it, but I commend you for your work. Kids like me are sitting in the tech classes of our failing public high schools twiddling our thumbs, learning nothing. Things like Botball, FIRST robotics, and hopefully this project really help us alot.
1
2
of 2 Next
