Posted by Howard Gordon on August 24, 2008 at 7:30am
From Yann's Techno Toy Blog ...Stanford Autonomous Helicopter Project has developed new reinforcement learning techniques to stabilize and control their helicopters. The developers have been able to teach their heli to perform just about every aerobatic figure imaginable. However, the heli has no on-board intelligence. Instead, data is fed from onboard GPS and IMU with serial outputs directly into Xbee Pro modules. The signals are received by a PC on the ground, which enables operator control via the training port of a conventional R/C transmitter.
These guys can afford to run the XBee's in half duplex & use a zillion channel transmitter for the uplink. Using the XBee's in full duplex is another trick.
That's a similar setup to mine although I haven't moved on to helis just yet. I've got dat streamed back to the pc via Xbees and then instructions are sent via the training port.
