- Capacitors:
- (C1)1x 100uF 16v 399-5214-1-ND
- (C4)1x 100uF 6.3v 478-1677-1-ND
- (C2,6,12,13)4x 0.1uF PCC1828CT-ND
Diodes:- 4x Navi LED (green) 67-1357-1-ND
- 1x Power LED (red) 67-1359-1-ND
- or optional (blue) LED 160-1643-1-ND
IC's:- (IC1)1 x Atmega168, ATMEGA168V-10AU-ND
- (IC3) 1x7805 voltage regulator: 296-22950-1-ND
- 1x L293D(motor controller)296-9518-5-ND.
- 4x IR sensors (Pololu)
- 1xMaxbotic ultrasonic sensor EZ2 or EZ3
Resistors:- (R1, R8, R9) 3x 10kOhms P10.0KCCT-ND
- (R2-R6) 5x 1Kohms P1.00KCCT-ND
Switches,etc (Sparkfun):- (S1) Switch
- Reset button
- 1 strip of male pin headers
- 1 strip of female pin headers (to plug the removable ultrasonic sensor into)
Code coming in a few days
Right now we're just using the standard thickness. The board itself is really small (just under 2" square) so there's not a lot of volume there. We saved weight with a SMD power supply and switching from the Parallax to the Maxbotics ultrasonic sensor, and we're well under the weight budget for the blimp, so I think we're okay for now.
