Posted by Jordi Muñoz on October 1, 2008 at 2:30am
This is a nice example of how to control Google Maps.With this Labview VI you are able to:1-Control the center Point of the Map with the desired coordinates.2-Control the Size, Zoom and the Format of the Map (terrain, hybrid, etc).3- You are able to put multiple balloons, and change color, size,, etc.4-You are able to draw paths between the center point and the balloons.You can attach multiple GPS and display the position of each with a balloon, please modify it to your needs.The bad: Is a little bit slow, depending on your internet connection.Files:Google_maps_by_Jordi.zip
hola jordi,
I would be interested in programing this in PHP... I know how to do it for un*x systems (serial to php etc). The user would only need to have a web server with php and a serial connection, the rest could be scripted.
Do you think this might be interesting to the rest of the users?
VVVery cool project BTW!
I was testing the vi attached and I cannot seem to add new paths.
How do I add path balloons?
Thanks,
Martin
LabVIEW + Google Earth
How do you use your VI? To plan UAV routes?
