I've used two GPS loggers: the i-Blue 747 Bluetooth device from Transytems, and the Trackstick II. The first I can recommend highly; the second I can't recommend at all. Here are the facts so you can make up your own mind.
[Note: the software communicates with the device via a virtual Com port, handled by a driver. It can be a little tricky to figure out which Com port, however, so I suggest you go to your Windows device manager and see which port was assigned to the device and set the software to use that. On one of my machines it was port 5; on the other it was port 10; it depends on how many other drivers you've already loaded.)
It also saves GPS positions once per second, which is important when you're trying to match it with pictures you're taking at least that fast. In our testing, it aquired a satellite lock in less than minute and was rock-solid in keeping it, even when we just tossed the device randomly into an aircraft's instrument bay, buried under other electronics and bathed with other radio emissions. Basically, we've used this devices on dozens of flights, UAV and otherwise, and its performance has been top-notch.
In testing, three serious problems cropped up with the Trackstick (aside from it being expensive, big, and badly underfeatured):
- It only records a GPS record every 15 seconds in low-power mode and every 5 seconds in high-power mode. Even at the highest, battery-draining settings, that's way too slow for aerial mapping.
- It takes forever to get a satellite lock. The first time, it took more than half an hour and subsequently it took more than three minutes.
- Keeping that satellite lock is a struggle, too. By having a terrible GPS chip that only sees 12 satellites, the Trackstick II suffers from frequent drop-outs and glitchy datapoints. We found it essentially unusable.
Thanks for the pointer to the Sony unit. Like the Trackstick, however, I think it's not appropriate for UAV use. It only tracks 12 sats and saves data points every 15 seconds. When you're taking pictures twice a second and the direction vector is important in properly placing the shot on a map, you need to sample GPS at least once a second. These little planes can bounce around a lot.
I already have the Picopilot GPS but I was thinking of needing only one for logging AND navigation - however the 747 might be practical as a stand-alone I think.
Gary - thanks for the link!
Cheers,
Bjorn
I think I'm right in saying after you use it you sync it with the camera and it derives position, I've done no more than glance at the web page so could be wrong.
I have a Nikkai bluetooth GPS which works very well with my Nokia cellphone to send position via GPRS/3G that cost about $70 from Maplin here in the UK. Its not as feature packed as the i-Blue 747 that you mention.
It captures signals very quickly and even works really well in my house, I'm very impressed its much better than my old Garmin handheld.
Cheers
G
U ordered a i-Blue 747 for your picopilot?
I thought the picopilot already have a GPS receiver?
Rgds,
fuhan
Bjorn
I don't have it front of me so I can't tell you for sure, but it's light as a feather. Maybe the weight of a regular servo?
This is what I have been looking for to replace my Garmin Geko 201 as logger.
What is the weight of this unit (the i-Blue)?
Would it work to drive the Picopilot (RS-232 levels)?
Thanks,
/Bjorn
