Back in the air - for about 10 seconds
The flight
My new parts arrived on Friday. Included in the order was a new RC plane (Firebird Phantom) as well - it turned out that it was cheaper to add the complete model to the order rather than ordering each of the parts separately. So, on Saturday morning, I took my new bird out for another spin.
The winds were much closer to ideal this time, and I imagine they were well within the tolerance of the UAV to maintain control - given a reasonably competent operator.
I launched the Phantom by hand and maxed the throttle to get it some altitude. I am always surprised by how fast that thing gets into the air - it climbs on what seems to be a 60+ degree angle when at maximum throttle. With the surprising rate at which it went up, it was likely only at 50 feet when I reactively released the throttle - which caused it to immediately dive. Not being able to think clearly about what I was doing, and not having (although rapidly gaining) the experience needed to settle the craft down, I moved the throttle to maximum again.
The little bird started accelerating towards the ground, under its own weight and powered downward by the thrust. As before though, the dive quickly gave way to a steep, rapid climb - and I released the throttle again.
This time, the peak of the arc was lower than the first peak, and so it started to dive - towards a cement parking lot - with a lot less room to correct for my previous over-corrections. I maxed the throttle again, and the Phantom started to pull out of the dive. It looked like it was going to make it too - the trough of the dive was at about one to two feet from the ground - but I didn't notice the parked car directly in the flight path.
SMASH!
The tail virtually shattered on impact (no small feat for a craft built almost entirely of foam), but the fuselage appeared to survive due in large part to the soft nose. I ran over to the car and inspected the scene to see that the car had definitely come out of the ordeal with the better bargain - nary a scratch.
I collected up the pieces of my 2nd Phantom and returned home. My cumulative totals as an RC pilot stand at around 90 seconds and two crashes.
Lessons Learned
The Phantom should be easy to fix. I ordered a replacement tail with the Phantom that I just crashed, and will put another order in for more parts - they will hopefully be here before I need them. I've also decided that I need to get my plane to higher altitude. The Firebird Phantom comes with built-in ACT (Anti-Crash Technology), but I think it needs to be at a high altitude to be able to activate and auto-correct in time.
I'm nervous about taking the plane to higher altitudes though, because there is built-up areas surrounding the park that I fly in. So, for my next flight, I'll be heading out to an area on town called the sandpits. It's a couple Km out of town and should afford me the freedom of space I need to experiment with higher altitudes and longer ranges.
Darkness arrives earlier and earlier now as we move towards the winter solstice, so this flight will likely have to wait until next weekend. That's fine - I need the time to rebuild my Phantom.
Until then - thanks for reading.
  • I also got a Phantom, but lost it in a deep woods when I forgot the most basic thing -- I didn't extend the antenna before launch! You will find that the quickest way to recover from situations such as you described is to just take both hands off the controls! The plane will recover by itself, though you do need a little altitude.
  • also pierre, the first time out with my easystar, I didnt get 3 mistakes high and circle low into a pine tree instead aboout 40ft up, my only retrieval tool a 5 lb chunk of concrete, I broke the prop and gave the fuse 1 or 2 small dings in 50+throws but finally got the easy* back intact minus a prop. The plane is incredibly tough due to elapor foam and is quickly and easyily repair with boiling water (elapor soup!) and a hot melt gun(used sparingly)
    gwen
  • Hi Pierre,
    Dont waste your time on the firebird or other POS.
    Get a Multiplex Easystar(I have 2), dont waste your hard earned time or money on anything else. Get a PPM(Trainer cord to USB) for your transmitter. Download FMS and the easystar simulation for same(its all free) and learning to fly the easy* on simulator first and then choose a windless morning and a VERY large field for your first flight, MAKE SURE YOUR C/G IS SET at 78mm for the first flight. Go 3 mistakes high for safety(ie about 150-200'.
    be prepared to buy another easystart parts kits after you learn to fly.(about 54.00).
    good luck and the above if followed will cut down your expenses severely!(its the way a lot of us self taught pilots finally find)
    gwen
  • I'm hesitant to upgrade a model almost twice the price when my record is so poor, although your point about having an elevator definitely makes a lot of sense.
    My real problem right now is exactly as you're said: over-control. I don't yet have a good feel for how the bird behaves in the air; that and natural jitters (this is exciting stuff!) combine for little more than a crash and a story.
    If I continue to encounter problems with people leaving the ground too far up in the sky, I will only need to wait a few weeks - maybe as few as three - before there should be a nice fluffy bed of snow making it almost impossible to destroy it.
    BTW, I teach computers at the local college here and I thought you'd be interested to know that I showed your TED talk to my students the other day (one of only three). It was well-received.
    Pierre,
    Yikes! Needless to say, gently does it, include in throttle moves. Rather than going 100% to 0%, try bringing it down to just 50%.
    Also, you might be better off with an elevator. The next plane up for you might be the Aerobird 3, which is about $110. (http://www.hobbyzone.com/rc_planes_hobbyzone_aerobird_3.htm). But I'd give the Phantom one more go before giving up. The fewer things to control, the quicker you'll get the hang of it.
