There are a few obstacle detectors and rangefinders on the market, but are usually either very expensive or don't work
great outside (I am looking at you Kinect). We decided to try to make a product that it is cheap and rugged enough to be used outdoors.
Here are some parameters:
- detectable range: 200 mm to 1500 mm (7 to 60 inches )
7.5 degrees angular resolution
2 scans per second
180 degrees view
easy readable output data in text format
easy interface with other boards it comes pre calibrated
USB interface power and data
It is intended more for terestrial robots (is a bit slower than the laser rangefinders) .
Here is the link
RS232 isn't a plus for me, but it might be for other people - on the computer side I'd just use the USB interface, which I imagine is just SPP, right? As far as the physical connection for SPI, it doesn't matter to me... The only 'nice' feature related to SPI I can think of would be if your hardware also did the level shifting so it worked with both 3v3 and 5v logic, but that's easily addressable on my side (I just always appreciate devices that do that). I don't have any experience with developing for CAN, so can't comment on that, other than I don't use it (but not for any particular reason). ;)
Would be ok If there is an RS232 port with a DB9 connector that also exposes a SPI interface?
Guys,
Thanks for information.
Any help that you can provide with the campaign , I would be deeply in debt to you.
Harry
@Harry,
I have worked with both the short and long range Sharp IR sensors and they were marginal in an outdoor environment at the speeds that our rovers were travelling at.
I suspect that they will work well indoors and I believe that your sensor will be perfect for that environment.
TCIII AVD
CAN bus is indeed better as immunity, but I am afraid that a lot of people might be put off by complexity, and also needing hardware.
@Harry,
CAN bus is getting to be the way to go for peripherals as it has good noise immunity compared to RS232 or SPI/I2C.
TCIII AVD
Hi Mark,
would a RS232(UART ) work for you. This is in interface that we were thinking about adding.
And it would be nice to actually see some live video showing your prototype doing something... Show your app running on the computer, and the device, and move things around in front of it showing how well it does at detection, etc.
Looks interesting, the price is attractive as well - I have one concern and one dealbreaker for me... The concern I would have is that when I used those Sharp sensors in the past, I had problems with them in sunlight although they worked fine indoors. The dealkiller for more is the USB interface - I think that's cool if you're hooking it up to a computer, but it really should also have either an SPI or I2C interface, I would think either one would be simple enough to add, and then it gives me the ability to more tightly integrate it with the hardware. If you had I2C or SPI I'd pull the trigger, but in general the bots I build don't have USB hosts on them...
Thanks Gary,
you are certanly right.While the performance of the other scanners are better , also they are more expensive.
Also we tweaked a bit the price and now it is $139 for a unit .
I think it is a great unit for small robots .And we offer software and support.
Harry
