A rainy weekend in Switzerland
After reading the "unboxing ArduCopter" the rainy weekend came just right. I already made some drawings in the mornings when waiting to wakeup the kids at 7.
Some drawings, parts, testcuts
The machine
Some parts
Some more parts
The result
Details
More details
This is it. I hope to have the maidenflight soon.
Thanks to all ArduCopter people for the inspiration and the code.
Cheers Christof
  • I made the parts with a very tight fit. Then assabled them with a little hammer and put a drop of thin CA at the joints. I was sanding the ciontact area a litte bit. thats all and the frame is extremly rigid.
  • any suggestions on the glue to make the parts?
  • The lower body and the motormounts are 2mm carbon, The upper construction 1.5mm carbon. The parts are made on a CNC milling machine. You need hard metal bits with a diamond cut. 1.5mm - 2mm. tey are cheap (2-3USD) and work quite well.
  • oh yea i had that problem too, my speed controllers were working, then the alpha code which runs at 200hz, made it incompatible.. so im looking for compatible speed controllers.
    those are carbon fiber plates right? how are you cutting them with a mill, i thought the drill bits cant handle carbon fiber...
  • That is a lokal brand called ePower. Its very Important to setup the controllers amnually to your Radio. At first, not all motors where starting correct so I had to change the startup mode to "very soft". Now it works awsome. I had to adjust the PIDS quite a bit. The first flight was shaky and unstable.
  • amazing, how did the pid tuning go? i saw the video looks very stable. Im having problems with an incompatible speed controller, what is the speed controller you are using?
    definitely an inspirational build for me,
  • The Quad is finished so far, PID's adjusted and its waiting for the video payload.
    Total weight 1610Gr with 4400mAh 3s
    Hovering current is 19A
    @ 75% batterie usage the flying time is +- 10min.
    Thanks again to the AC team. The code is very stable. I am looking foreward to test the GPS features.
    Best
    Christof
  • Thanks for the good wishes.
    Morli, its just a "design shape". I thought it would look nicer than straight. And whats a CNC machine for? Cuting nice curves...
    I had my maidenflight today and it worked out quite well. I had the copter in stabilize but it was oscilating in pitch and roll at maybe 3-4 Hz to an angle of 10° per side. I was using standard PID's.
    Does anyone have some suggestions where I should start tuning?
    Christof
  • Know what you mean... good job! look like mine:)
