A World Breakthrough in UAV Propulsion
3689568566?profile=original
Energy Density of up to 0.65-0.8Wh per gram.  Very Exciting!
Excerpt from Manufacturer's Website
AEROPAK is an ultra-light power supply enabled by fuel cells, designed to increase flight endurance for small electric Unmanned Aerial Systems (UAS). It uses an on-demand hydrogen supply system from a chemical stored in a swappable cartridge.
The special characteristics of AEROPAK-1 allows to reduce weight progressively over the course of a flight, by purging spent fuel during flight. This means the average energy density of the system can increase up to 675Wh/kg for a 2 kg system, weighing 1kg after consuming all of its fuel.
3689568541?profile=original
Excerpt from Isreal's Homeland Securty Home
A cooperation between Israel and Singapore has resulted in a breakthrough in powering unmanned air systems. “This will change the world of UAVs and opens many new paths for using them in many applications” an Israeli source said.
3689568587?profile=originalInformation Document
3689568604?profile=original
  • Aeropack is a great product, but especially for fixed wing.
    The fuel cell systems may have, even with a buffer lipo battery, low rate of discharge with respect to their capacity.
    So for rotorcraft systems are difficult to use, unfortunately
  • Be sure to check out Simon Howroyd's earlier posts part 1, part 2 and part 3 to follow the progress of one of us already making headway in this area.
