ACM2 tricopter AUTO and ALT_HOLD test
3689414623?profile=original
3689414581?profile=original
ACM2-logs-2011-06-30.zip
ACM2-Tricopter-Config.param
ACM2-logs-2011-07-02.zip
I set the altitude to 18 - 28 meters high but it went to near 100 meters high,
I was a little nervous since I almost can't recognize how it's flying.
All I can do is trust ACM2, I have both sonar and compass on it.
I felt the throttle control response in ALT_HOLD mode is not sensitive enough.
I used the latest ACM2 code which was downloaded today.
Logs and config files are attached FYR.
    The server is working again. You should get 2.0.31 when you use the planner.
    Jason
    hmmm. I told the server to recompile it about an hour ago. I'll try again.
    Jason
  • Jason,
    I run planner and try to download tri FW, it still show AC 2.0.30 beta tri.
    Did you update it, or just ther version number was missed?
    Thanks.
    -Cliff
  • Answer to RJBK
    min 4:21 was in altitude hold mode.
    Had posted the config file on top.
    Thanks.
    -Cliff
  • Thanks for the quick fix, Jason
    The wind was tiny, will try 2.0.31 and post the result soon.
    Cliff
    Cliff,
    I examined your flight and I've made a number of tweaks to PIDs and crosstrack error.
    Could you upload 2.0.31 and try this mission again? I think the comparison would be tremendously helpful!
    I'm pretty sure you'll see a big difference. Again, thanks for the logs, they were amazingly helpful.
    Jason
    Here is your alt hold graph - pretty high! 230m3692232104?profile=original
    Here is your WP nav:
    3692232131?profile=originalLots of hunting. We should be able to tune that out. How was the wind?
    Cliff,
    Thank you for your log. It was very helpful and revealed a bug in altitude hold. I have fixed the code and will post it shortly.
    I also noticed that the sonar was not reporting correctly. This may be a bug as well. I have been seeing a lot of bad or false sonar reads lately so I reverted to the previous library code for sonar. If you could erase your logs and do a new flight with your sonar on I would appreciate it. With the newest code of course. Look for 2.0.31.
    Jason
  • min 4:21. what is flight mode?
  • so nice..
    when the 3C facing you, what is flight mode? loiter or hold alt only?
    can you share you configuration file setting?
    thank's before
