I just got a Quanum Nova, which is a fantastic APM-powered copter that in many way outperforms the DJI Phantom for less than $300. Although it's capable of full autonomy, just like any other ArduCopter, the one thing it's missing for easy field mission planning and DroidPlanner compatibility is telemetry.
In this great tutorial, Jean-Louis Naudin shows how to add that:
Here an explanation for connecting the real time telemetry to the CX-20 or to the Quanum Nova
The telemetry port is located on the I/O board of the APM (the second board at the bottom and pluged to the main CPU board) where all the I/O plug are connected. The telemetry port is fully compatible with all the telemetry transmitter (3DR and all the compatible boards) and also with the Bluetooth boards commonly used with the APM boards.
Below the pinout which shows the telemetry port I/O (back to the I/O board).
Note from the comments: depending on which radio you're using, you may have to reverse the TX and RX lines. Dmitry in the comments reports: "You must connect RX from the radio to TX on the APM! And vice versa for Radio TX. So I've changed green and yellow wires and it works!"
sold 4 cables on the telemetry ports
then protect the connections with hot glue
Check the functioning
The 4 pins telemetry plug is installed on the back of the fuselage
Check the connection (at 57600 baud) with the mission planner or the Droid Planner 2
Then, you may enjoy to use the telemetry...
NEXT CHAPTER: Full autonomous mission with the Cheerson CX 20
Here the CX-20 factory param file:
https://github.com/jlnaudin/x-VTOLdrone/blob/master/param/CX20_PID_...
@PF: you will find the AC 3.1.2 firmware source in my GitHub at:
https://github.com/jlnaudin/x-VTOLdrone/tree/master/ArduCopter
JLN
@PF: I suggest you strongly to reload the original AC 3.1.2 firmware which gives excellent result with the mini-APM installed on the Cx-20 (Nova).
Look at my onboard video with a GoPro 3 and see by yourself the result...
Do not change a winning team...
Jean-Louis
Hello PF,
The CX-20 (Nova) fly perfectly with the 3.1.2 Arducopter firmware... So why upgrading or changing something here ?
All details are posted HERE
Best Regards,
Jean-Louis
Dmitry, I've edited the post above to include your comment. Thanks!
I had the same issue. You have to solder directly to some tiny pins on the board. http://www.rcgroups.com/forums/showthread.php?t=2112759&highlig...
Make sure tx is going to rx and vice versa.
Wow! Just what I needed. If only the person at HK's chat line had pointed me to this video, It would have solved a lot of hassle.
Thanks!
Check this video out. If it doesnt answer your questions please be more specific and we can help.
https://www.youtube.com/watch?v=jnhXSI2sTa0&feature=youtu.be
I need some help - hopefully someone that has experience with this machine. I bought one from HK without a radio.
See my earlier post in the "uncategorized" section.
My Bluetooth works with droid planner 2.0... See my post http://www.rcgroups.com/forums/showpost.php?p=28753951&postcoun...
1
2
3
4
of 4 Next
