Airframe testing
Before commiting expensive gear to an anything and in the interests of I wonder.I have been flying this airframe quite hard.Yesterday I load tested it using five of these at 58g each the multipack 5 came to 290gWithout load I have achived flights in the order of one hour obviously that will change.The aircraft has a 40 inch wingspan and easily fits on the back seat of my car. A simple solution for when we go out and get this sort of shotWorking towards an Attopilot being fitted for vertical stitch shots of archaeological stuff.On the drawing board a more efficient wing and larger, probably just shy of 2m easily able to lift 500g for one hour.A platform nose for FPV/Stills cameras and plenty of internal space for vertical/horizontally mounted cameras and gear.Flat wing this time with outboard ailerons. The airframe being roughly double this ones size. Also thinking of having a small or large wing for different tasks or wind speeds.Hopefully some pictures of a rough setup within the month.This bigger airframe will be used for some animal research tasks in Kenya, Tanzania and South Africa. Mostly lifting repeaters for animal tracking collars.For test Airframe 1, I have set up a TwitPerhaps the first UAV airframe with its own Twitter feed??I am hoping to fly 100 hours in the next month or two, so far I am ahead of schedule but weather is coming next week so I'm sure that will get in the way.
  • T3
    I would appreciate large bomb bay under the COG, and smoother fuselage near engine 'firewall'.
    Because of noise, I would like to see enough room for 7inch propellers propelled by AXI 2217 outrunner.
    I believe it is easier to make robust control surfaces with classic layout, because there is more adhesive surface. Also, following the experiences from easystar, I would add much more vertical stabiliser, reduce dihedral, add underfuselage fin (to fight hunting oscillations).
    Its made from EPP, foam!
    Here it is with its sister!
  • Your airframe looks good. What have you made it out of?
