An autopilot in the sky - Project SensePod
3689648019?profile=original
I’ve been experimenting with a small analysis package I originally called the SIXPack (Scientific X-Pander Pack). The idea is to have a module you can slap on to (almost) any drone. The module contains a microcontroller and storage device, and can house one or several sensors ie: gas, light, air sensors or cameras.
The module gets it’s power from the drone and is also able to receive telemetry data and merge the data with the sensor data, providing a full set of telemetry and sensory data which is stored to a sdcard (or sent back to planet earth through radio).
Early version
Yesterday - I flew a kind of mock up version, let’s call it the Ugly Betty version (on the following pictures you’ll see why).
3689648088?profile=original
The electronics is contained in a standard mains junction box, which is kind of nice because of it’s IP56 water resistant seals but a nightmare aerodynamic wise. The particular box contained the mentioned microcontroller and storage device together with a Methane gas sensor. Power and telemetry was supplied from the plane.
3689648160?profile=original
A short testflight revealed that everything worked nicely, and that some interesting readings were made and merged with the IMU telemetry (GPS, altitude, etc….). Below graph is just a plot of the flight - more flights are needed to evaluate how good the measurements really are.
3689648033?profile=original
It also felt like flying with the handbrakes on.
Is it a bird? A plane? No it's a plane (or bird) with SensePod!
Luckily I’m so fortunate to not only have access to a 3D printer, but also a guy who really knows how to get the best out of a 3D printer. So I started up my good old Shade 3D software and started to design a nice aerodynamic enclosure for the SIXPack.
3689648215?profile=original
The SensePod (as I call it) is assembled from two almost equal halves. The bottom part can be replaced with different versions for different sensor configurations, and it also features a plug connector for external power and telemetry.
3689648190?profile=original
The pod will have ample of space to piggyback a microcontroller, storage device along with some sensors etc...
I also considered adding wings to it to compensate a bit for the extra weight it induces, but I'm not an expert in aerodynamics so I thought it best to leave that idea for now. The thought however, that you would also be able to drop off the pod in mid air and let it glide back to earth is enticing :-)
Next up is printing the Pod in a miniature size to make sure everything is modelled correctly, then the real thing is printed! I'll post an update and first flight postmortem.
  • I see three main reasons for using a pod;
    1. Experimentation and fun - today you want to experiment with gas sensors - tomorrow you want to do some nir photography - just exchange the pod and you have a completely different sensor beast - quick and easy.
    2. Some sensors require special care - the gas sensors i use has a heater, and gets quite hot during flight - I wouldn't recommend placing it in an epo wing, you might melt the wing or dissolve the glue. Also a certain airflow is best to get exact readings, so it's better to not expose the sensor directly to the "outside" but rather have a steady flow of air streaming through the sensor through a funnel.
    3. Ease of use  - Let's say you are a farmer - you are not that familiar with the insides of a drone - can't reconfigure it for different purposes. By just putting the "Crop analysis" pod on his standard drone, he get's a nice way to do crop analysis. Exchanging the pod with the "Count my live stock" pod, he can easily and without much technical knowledge do something else with the same standard drone.
  • What are the benefits - other than waterproof - of having all of the modules in one 'pod'? I like the idea of a universal sensor hub.
    Since most drones are not waterproof would it not be easier to keep the parts modular so the individual sensors and components can be distributed throughout the frame (e.g. methane gas sensor on wing, light sensor on near, microcontroller and storage device near Pixhawk controller to connect to telemetry, etc.)
