Here is my APM2.5 at my apartment in Albuquerque NM. See the 3 waypoints and home position?
Thanks a bunch Kevin! http://www.diydrones.com/xn/detail/705844%3ATopic%3A1094076
My android tablet is a Pipo S2 at $122 from Banggood.com What a deal! There are some things you have to do to get it to work on the S2 (new firmware) but it is east.
Earl
also setting params
yes.
seems to work as is... is the software functional, as it stands now just for altering flight modes and viewing gps position?
Matthew - you can first try plugging a powered USB hub in between the low power tablet and the radio.
I have a note 10.1 and a USB adapter but its low power USB.... will this be an issue? could i just use a serial cable and power the 5v from a regulator keeping only common grounds?
Thats a Pipo S2 like I am using....Works great. Put the Pipo S2 Ultimate 3G firmware on it to get the usb host mode to work correctly.
Took me a while to find this trick.
Earl
Also - no need for a rooted tablet (though rooted should be fine).
To get 3G it is quite easy to tether to the phone in your pocket - no need for a 3G dongle. Btw: minimum supported android version is 3.1 - it won't install on earlier versions (no USB host mode).
Earl, it does not have inbuilt 3G, requires 3G dongle, not that good, b'cuse while you are in flying field, this tab to act as GCS, you require high speed internet 3G to live track fast moving autopiloted plane in GE.
And you know, hooking up 3G dongle and 3DR radio at the same time would be quite cumbersome.
