I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
And here's the impressive work of the AeroQuad team:
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
Here's the announcement from the AeroQuad team:
ArduCopter - The Full Featured UAV Multicopter!
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature ListSoftware Roadmap
- 6 Degree of Freedom IMU stabilized control
- Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
- GPS for position hold
- Magnetometer for heading determination
- Barometer for altitude hold
- IR sensor integration for obstacle avoidance
- Sonar sensor for automated takeoff and landing capability
- Automated waypoint navigation
- Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
- On board flight telemetery data storage
- Mounted camera stabilization capability
- Wireless command & telemetry for long distance communication
- Capability to fly in "+", "x", hexa and octo configurations
- Battery level detection
- User configurable LED flight pattern
- Capability to use any R/C receiver
- ArduCopter Configuration and Ground Control Software
- Realtime graphs of flight data
- GUI for configuration of PID and other flight parameters
- On Screen Display integration
- Waypoint programming using Google Maps
- Mixertable view to auto configure "+", "x", hexa and octo configurations
- Initial baseline using Jose Julio's v3 software
- Provides absolute angle PID flight control
- Obstacle avoidance
- Waypoint navigation
- Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
- Emphasis on developing new capability into easy to use C++ libraries
- Integrate user defined EEPROM storage capability
- Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
- Integrate AeroQuad Configurator for external software configuration of ArduCopter
- Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
- Integrate AeroQuad rate PID control
- Integrate mixertable configuration for multicopter configurations
- Integrate AeroQuad camera stabilization
- Integrate I2C motor control
- Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
Does the "low-cost custom platform" mean the frame components? I'm set to buy my structural supports, motors, esc(s), props, and battery tonight for my build. Then, I'm going to add the ArduPilot Mega and the 'Oil Pan' when it is released next week. Does that sound like a reasonable plan? Or, is it wise to wait for the whole package to be released?
Chris stated that hopefully the whole package will be around $350 USD. And yes, it is open source
In a friendly way
dody
# GPS for position hold
# Magnetometer for heading determination
# Barometer for altitude hold
# IR sensor integration for obstacle avoidance
# Sonar sensor for automated takeoff and landing capability
# Automated waypoint navigation
# Waypoint programming using Google Maps
Currently there is already altitude holding with sonar, IR sensor obstacle avoidance, GPS position holding, camera stabilization etc.. So most of the functions are already available we just need to make it as one neat packet.
So yes it will have both RC and autonomous
Due ArduCopter is project that was just started some days ago there is not any official/semiofficial/unofficial sources yet. Future codes will be based on both Jose's & Mikro's codes. Those codes you can find either from here or from AeroQuad website (tho both repositories are on googlecode). So check out them first and let's wait untill official development kicks off.
Cris mentioned on somepoint that first release should come out in around 2 months or so.. So let's wait and see. Till then we all are working with our own projects and codes.
Our code for our special designed hardware you can find from http://code.google.com/p/lnmultipilot10/
there is port from Jose's ArduIMU code and also Mikro's AeroQuad code also for this platform.
And official AQ code can be found from http://code.google.com/p/aeroquad/downloads/list
76
77
78
79
80
of 82 Next
