I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
And here's the impressive work of the AeroQuad team:
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
Here's the announcement from the AeroQuad team:
ArduCopter - The Full Featured UAV Multicopter!
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature ListSoftware Roadmap
- 6 Degree of Freedom IMU stabilized control
- Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
- GPS for position hold
- Magnetometer for heading determination
- Barometer for altitude hold
- IR sensor integration for obstacle avoidance
- Sonar sensor for automated takeoff and landing capability
- Automated waypoint navigation
- Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
- On board flight telemetery data storage
- Mounted camera stabilization capability
- Wireless command & telemetry for long distance communication
- Capability to fly in "+", "x", hexa and octo configurations
- Battery level detection
- User configurable LED flight pattern
- Capability to use any R/C receiver
- ArduCopter Configuration and Ground Control Software
- Realtime graphs of flight data
- GUI for configuration of PID and other flight parameters
- On Screen Display integration
- Waypoint programming using Google Maps
- Mixertable view to auto configure "+", "x", hexa and octo configurations
- Initial baseline using Jose Julio's v3 software
- Provides absolute angle PID flight control
- Obstacle avoidance
- Waypoint navigation
- Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
- Emphasis on developing new capability into easy to use C++ libraries
- Integrate user defined EEPROM storage capability
- Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
- Integrate AeroQuad Configurator for external software configuration of ArduCopter
- Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
- Integrate AeroQuad rate PID control
- Integrate mixertable configuration for multicopter configurations
- Integrate AeroQuad camera stabilization
- Integrate I2C motor control
- Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
We know that there are many people out there that has millions of questions on "HOW?!?" and we are trying to provide answers on those.
Also there will be upgrade parts to basic frame due some people want to do more than just fly around their backyard. First we just need to get out initial set of quads :)
I think that it is very important ( for the newbies like me) to have some information about the relationship between: motor spec / size of propeller / maximum weight of the quadcopter that they can support.
Besides all the software and other hardware considerations this is (for me) the most confusing thing.
I´m shure that Jani will provide a kit with the correct motors and propellers for the frame and hardware they are developing to sell in the DIY store...
Tho there are few things that needs to be changed, we will do all instructions for those. But for now, no need to change. Use Configurator. And remember software in our repository is not even Alpha release so be careful with it, check check and double check before flying first time.
For people who asks about propellers, we are currently looking propellers, in future you can get them all from DIY store too. In meanwhile you just need to get them from where ever you find. AeroQuad.com, HobbyKing, Quadroufo.com and many others.
#define acc_offset_x_ADR 80
#define acc_offset_y_ADR 84
#define acc_offset_z_ADR 88
#define gyro_offset_roll_ADR 92
#define gyro_offset_pitch_ADR 96
#define gyro_offset_yaw_ADR 100
Also, is the GEOG_CORRECTION_FACTOR_ADR the cosine of whatever latitude I'm at? For example, if I were at exactly 45°, cos(45°) = .7071? That is quite a bit different than the default of 120...is it multiplied by 100?
Where can i buy this counter clockwise propellers? i already have this:TowerPro BM2410-9T / 18A BEC/ 1047 Prop Comb.
This one will fit? :
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
Any other sugestion?
Thank you
65
66
67
68
69
of 82 Next
