Another cool hack of a toy quadcopter
3689559518?profile=originalFrom Hackaday:
Building your own quadcopter is an expensive and delicate ordeal. Only after you navigate a slew of different project builds do you feel confident enough to start buying parts, and the investment may not be worth your effort if your goal is to jump right into some hacking. Fortunately, [Dzl] has a shortcut for us; he reverse engineered the communication protocol for a cheap toy quadcopter to work with an Arduino.
The cheap toy in question is this one from Hobbyking, which you can see flying around intheir product demonstration video. [Dzl] cracked open the accompanying control handset to discover which transceiver it used, then found the relevant datasheet and worked out all the pin configuration involved in the SPI communication. Flying data is transmitted as 8 byte packets sent every 20 mS, controlling the throttle, yaw, pitch and roll.
[Dzl] took the build a step further, writing an Arduino library (direct Dropbox download link) that should catch you up to speed and allow you to skip straight to the fun part: hacking and experimenting! See his quick video after the break, then convince yourself you need a quadcopter by watching this one save its creator, [Paul], the trouble of walking his son to the bus stop.
  • I have been working on a similar idea with my Hubsan quadcopters. Their entire line of helisl/multis uses the same protocol, and even their upcoming mini with a built in GPS unit will use the same protocol. I hope to use the ability to interface with a computer, or smartphone, and telemetry feedback of location to develop auto pilot software for the $200 quadcopter. In the meantime, I am working on controlling my Hubsan micro FPV setup.
  • Very cool!
