Here's another cool autonomous vehicle project on Kickstarter. Pledge $400 or more and, if the project hits its funding goal, "We send you a remotely controlled 1m (3.2ft) long, articulated, inflatable Protei in KIT to assemble yourself. The design and functionalities would be similar to the one of Protei002 (http://goo.gl/dWG7p)."
"We are developing Protei : a low-cost open-source oil collecting robot that autonomously sails upwind, intercepting oil sheens going downwind. Protei combines conventional technologies in an innovative design that we can implement in the short term to address timely environmental crisis such as the BP Oil Spill, cleaning the ocean gyre garbage patches or performing ocean research. We need your help to build our next prototype of Protei - the first articulated sailing boat that can tack upwind pulling a long heavy payload and initiating a revolutionary family in ocean robotics. http://protei.org"
http://www.sparkfun.com/products/8785
I'm not entirely convinced that an articulated boat would be able to tack at low speed with a heavy drag on the stern. I sail a fair bit (Yes much to the dismay of my wife, I love the toys) and there is always the chance you can stall when turning through the wind. The articulated design is clever in putting the sail through the wind with the bow (and rudder) on the new course but a sailboat is not pushed forwards by it's sail, it's pushed forward by it's keel.
The most efficent and fastest way to sail is on a broad reach (perpendicular to wind direction) This is the point where you can bring your sheet right in and the sail is tight. The wind is deflected off the sail and because all of the keel in against the wind, forward movement is the fastest. When you want to reverse this direction you have to choices. You can tack (Bring the bow through the wind) or jibe (Bring the stern through the wind)
Even though the design appears to bring the sail through the wind via it's articulation, most of the keel is still behind the wind and so there is not a lot of keel transfering the perpendicular thrust into forward movement. Add a long oil soaked rag to this and I think you have pretty good conditions for a stall and eventually having your boat blown over the top of your oil skimmer.
I'm not trying to be a pessimist and it's a noble persuit but I'll reserve judgment until I see it tow the skimmer and make a tack through the wind.
http://www.kickstarter.com/projects/cesarminoru/protei-open-hardwar...
It's RC controlled, but shows how the steering works.
