Antenna tracker prototype up and running
I got the telemetry and videolink azimut / elevation antenna tracker prototype up and running the other day. Here is a video of it (without antennas) when it receives ASCII commands from the test software running on my lab PC.
Find more videos like this on DIY Drones
Preliminary specs:
720 degree azimut rotation range
>110 degree elevation rotation range
Relatively high torque
Ball bearings on shafts
Tracking controller programmable in C (Arduino based)
Commands to tracking controller can be sent via serial link from the ground control computer
ASCII based command protocol.
  • The cables are run inside the axle so the control cables are non problematic. The coax cables are looped. The controller will have logic that prevents cable jamming.
  • Jordi, care to elaborate on yoru project?
  • Do you have some logic to allow the antenna cable not to get twisted if rotated in the same direction all the time? Or a controller that is smartly tracks the turns in the cable?
    Just my 2 cents
  • Hi Jordi. The mechanics is servo city. The code is my own. I am building something modular that can accept commands from several sources.
    ServoCity right? But my Tilt and pan is the medium size.
    NIce! i have something like that already done, i will publish it soon. But i'm using ardustation.
