We've released APM 2.22, which has a bunch of bug fixes and improvements. MAVLink startup is now much faster and will work even if the hardware fails the calibration test. A bug in the driver for the new 5883 magnetometer is fixed. Various (mostly minor) navigation bugs fixed. MAVLink comms are also improved.
It's now available for download via the Mission Planner. Remember to go through the setup process again after loading (always a good idea after loading new code).
For those who need the source code, it's here. The next version of the code, 2.23, will have full camera control (both autonomous stabilization and point-of-interest following and a full suite of MAVLink commands) implemented.
Meanwhile, the Mission Planner continues to improve in leaps and bounds, thanks to the tireless work of Michael Oborne (subject of the next Meet the Developers post). New features that have been introduced in recent versions include:
- MAVLink logging is now on by default. Every MAVLink connection you make will be logged
- You can record your video! Just right click on the HUD as shown in the image above.
- Quadcopter hardware-in-the-loop simulation now works on both Xplane and FlightGear, just like the plane HIL sim
- Almost all APM and AC2 setup can be done via MAVLink. No need for the CLI switch or DIP switches!
- Lots of other performance and useability enhancements.
Chris can you respond regarding my previous comment that others are curious as to as well regarding whether or not there will be a 2.x "maintenance" type release that will support the older APM's while having a different release train that will be features and enhancements for the new APM's?
I'm referring to the one downloaded via MavLink, but now I have to connect using a USB, or use the logs file on the hard drive.
The MavLink file is just so much easier to use/access.
Hi Chris,
About two issues back, there was a tab that enabled you to save the flying mission to a directory of your choice.
Made it a lot easier to save and convert to .kmz "on the fly", so to speak.
I found the auto download file of my task today, I had neglected to delete previous missions, and the name/timestamp automatically assigned was a bit confusing.
In the end, I had to remove the wing and connect usb into the board, to get the data.
When I first started with the APM It was routine for me to have to manipulate the software to get it to work as desired. I haven't had to do that for some time now. Impressive work. "Props" to the developers, pun intended:)
Irvin: I've reworked that patch and now it's even easier to use.
There is one parameter CAM_TRIGG_TYPE here you can choose which type of trigger signal to use.
Then MavLink only has to implement one generic trigger, and the parameter will be used to select the right one.
The CAM_TRIGG_TYPE is documented in the code, but the latest version is not on-line yet because I do not have commit rigths, but I can send it to you if you want.
Tridge has posted a tutorial on how to do that here:
http://diydrones.com/xn/detail/705844:BlogPost:495858
1
2
3
4
5
of 5 Next
