[NOTE: There is a problem with autoupdate in APM Planner 2.0.9 (previous) to this release, users needs to manually update to this release from http://ardupilot.com/downloads/?category=35 ]
Some highlights of items new in this release
- AUTO TUNE support for APM:Plane
- New Primary Flight Display
- Google Maps Support fixed
- Linux Auto Update added
- TLOG replay (requires a fix :( sorry)
- Graphing improvements
- APM:Plane support for channel reversal and Elevons
see here for http://ardupilot.com/downloads/?category=35 downloads
Moved the file to home and tried again with partial success... Received the error
dependency problems prevent configuration of apmplanner2:
apmplanner2 depends on libopenscenegraph80; however:
Package libopenscenegraph80 is not installed.
Can't seem to find it anywhere to install it, but found this,
http://ardupilot.com/forum/viewtopic.php?f=82&t=7566&hilit=...
Should this be the solution?
You guys are doing a great job BTW.
@Michael, I tried the dpkg -i apm_planner2_latest_ubuntu64.deb before posting the comment, but got the file not found error. Does it need to be in the home directory before running the command?
Kenneth: That is the filename that you downloaded, if you downloaded the latest it would be dpkg -i apm_planner2_latest_ubuntu.deb or dpkg -i apm_planner2_latest_ubuntu64.deb
I'll make a bug report that it needs to be more specific about the command.
I'm installing apmplanner2 on Kubuntu 14.04 for the first time and get the message to use sudo dpkg -i apmplanner-XXX.deb to install dependencies but for the life of me can not get the proper syntax for the version to replace the "XXX". Could someone give me an example using the current version to use in this code.
So... I haven't had the chance to keep up with this, but, um, did you take out the OTP check?
thanks Bill.
where can I download the 2.0.9?
[erroneous comment deleted]
@Aaron: Thanks for the report. I've fixed the links for Linux builds now.
