APM Planner 2.0.10 release
3689596594?profile=original
[NOTE: There is a problem with autoupdate in APM Planner 2.0.9 (previous) to this release, users needs to manually update to this release from http://ardupilot.com/downloads/?category=35 ]
Some highlights of items new in this release
  • AUTO TUNE support for APM:Plane
  • New Primary Flight Display
  • Google Maps Support fixed
  • Linux Auto Update added
  • TLOG replay (requires a fix :( sorry)
  • Graphing improvements
  • APM:Plane support for channel reversal and Elevons
 see here for http://ardupilot.com/downloads/?category=35 downloads
  • There is now a 14.04LTS release available here: http://firmware.diydrones.com/Tools/APMPlanner/daily/2014-06-23/
    And will be available in every daily release after that (as well as stable). ubuntu/ubuntu64 is for 13.04(raring), and ubuntu_trusty/ubuntu_trusty64 is for 14.04 (trusty).
    or see http://diydrones.com/forum/topics/apm-planner-2-deb-package-on-ubun... for another workaround.
    We are working on building 14.04LTS with new releases. We should have a solution soon.
  • @Kenneth, sorry I only just got around to looking into this. I have both libopenscenegraph80 and libopenscenegraph99 packages installed on my ubuntu 14.04 . Looking in launchpad I see that the standard repositories do not have the "80" version. So I must have installed it from a PPA or manually. I'll try and figure out where I got it from. This probably means that everyone who tries to install apmplanner2 on a fresh ubuntu install has the same problem as you.
    libopenscenegraph80 : amd64 : Trusty (14.04) : Ubuntu
  • You could also just modify the dependencies in the .deb and see if it works with the new scenegraph library: http://superuser.com/questions/280370/how-to-easily-edit-control-fi...
  • I don't think I had any issuesinstalling on 14.04... I'll be at that machine this evening and I'll check what versions of scenegraph etc I have installed and hopefully be able to tell you something helpful.
  • By default Kubuntu uses QApt which is a QT-based app similar to gdebi. Just click on a .deb and you get a lovely install interface.
  • Is there an equivalent to gdebi for KDE? This is a graphical DEB installer for gnome that Domes with Debian and ubuntu. Very handy for people unfammilair with the shell.
    You may find some help here https://github.com/diydrones/apm_planner/blob/master/README.md
    check the dependencies part for linux
  • Kenneth: That is the filename that you downloaded, if you downloaded the latest it would be dpkg -i apm_planner2_latest_ubuntu.deb or dpkg -i apm_planner2_latest_ubuntu64.deb
    I'll make a bug report that it needs to be more specific about the command.
