Distributor
APM Planner 2.0 RC2 on Raspberry Pi
3689570947?profile=original
I just managed to get APM Planner RC2 running on my Raspberry Pi. I have not tested connecting to an APM yet but clicking around in the interface is much more responsive than i ever thought it would be.
Here are a brief instruction:
Install the required packages:
sudo apt-get install phonon libqt4-dev \ libphonon-dev libphonon4 phonon-backend-gstreamer \ qtcreator libsdl1.2-dev libflite1 flite1-dev build-essential \ libopenscenegraph-dev libssl-dev
Clone the repository in your workspace:
cd ~/workspace git clone https://github.com/diydrones/apm_planner
Build APM Planner:
cd ~/workspace/apm_planner qmake-qt4 qgroundcontrol.pro
make
Run APM Planner:
./release/apmplanner2
  • This project can no longer be built. I tried with the latest version of Mission Planner, and also grabbed the archived 2.0.0-rc2.
    It would be great to be able to try this out. Perhaps the RC Tech.se or Magnus might want to re-compile the thing from current library installs? I'm not familiar enough with the current QT (last work I did with it was in 2009) to figure out what the problem is.
  • I did try that, although on my Windows machine it is set to 115200 and that connects with no issues.
  • Should be 57600....?
  • I have this installed on my PI. However I am struggling to get it to connect to my APM 2.6, it seems to connect to the serial port but not to the APM. It is connecting too ttyACM0 @ 115200, anyone have an idea as to what I have wrong?
  • Hi guys,
    I had to try this, and I made a simple video showing the experience. I don't know much about Linux, but I was able to get it all working following RCTechs guide above. Thanks RCTech!
    Here is the video.
    https://www.youtube.com/watch?v=1Q1M9mO1DxY
    In essence: CPU is a big bottleneck, but I'd say that it could work OK if you can accept sluggish map panning.
    Experience is much slower with Telemetry and an open connection.
    KR
    Magnus, Sweden
  • Hi - thanks for this - used the instructions to install it on my server running lubuntu 12.04 - worked a treat.
    Will have a go on the BeagleBone later on.
  • Hi..congratulations....for installation in Beaglebone black the same similar procedure installation it's ok or need to diferent package?? I read Beaglebone offer hdmi output and arm7 processor....ubuntu works in videos I see in youtube...any of users here tried the Beaglebone black board??
    Regards
  • So cool, neighbor! :)
    I need to try this right away :)
  • Interesting
    Great work... Its good to see that this works without any unexpected hiccups.
