3689681531?profile=original
The team from Erle is at it again, with an APM-compatible board for the $5 Raspberry Pi Zero.  From Hackaday:
Flight controllers for quadcopters and other drones are incredible pieces of engineering. Not only do these boards keep an aircraft level, they do so while keeping the drone in one place, or reading a GPS sensor and flying it from waypoint to waypoint. The latest of these flight controllers is built on everyone’s favorite $5 computer, the Raspberry Pi Zero.
The PXFmini controller and autopilot shield is the latest project from Erle Robotics that puts eight servo outputs on the Pi, barometer and IMU sensors, a power supply, and all the adapters to turn the Raspberry Pi Zero into a capable flight controller. Since the Pi Zero will have some computational horsepower left over after keeping a quadcopter level, there’s a possibility of some very cool peripherals. Erle Robotics has been working with depth cameras and Lidar on more than a few drones. This makes for some interesting applications we can only imagine now.
The schematics for the PXFmini are open source in the best traditions of the RC and drone community and will be available soon
  • @Jaimie,
    you can find more info about how to feed it in our docs.
  • Can I use the power pins as a UART and power it via USB or RC pins?
  • Hi Tony,
    Only one UART port is provided in the PXFmini. If you want to connect several serial devices you could do it using the USB port or use UART-to-USB converters if needed.
  • I'm starting to think that the Pi Zero is not real.....  The damn thing is harder to find than gold is......
    Nicely done Victor and the other people at ErleRobotics!
  • Victor is kindly enough to make the schematic of PXFmini public here:
    http://erlerobotics.com/docs/Artificial_Brains_and_Autopilots/Autop...
    if you want a more pixhawk like cape for full sized rapberry pi (A or B factor), you can refer to:
    https://github.com/raspilot/Hardware
    I joined this project last year, and now code has been deleted from where it was cloned. home it will someday fix that 9250 driver onbard and pass the pull request.
  • @Victor
    I would like to add IR-LOCK to this quad, but it could double the cost! :) And if I add the SF-series range-finder, the cost might be tripled. Ha
  • @Thomas, that's quite the idea ;).
    @Alex, AFAIK the trend of including a coprocessor can be tracked to much before. The PX4 team started that and all the software layer is their doing. Have a look at their FCU designs and you'll see it yourself.
    I'm happy that the Raspilot guys brought this up to the Linux world and I like the idea behind it. It'll eventually make it into more of our designs.
  • the c1 didnt work with the navio+ and as this doesnt seem to be using any kind of coprocessor I doubt it will work with the c0. There is a video of a c0 concept of it flying of course odroid isnt giving any information on the board etc. Also with this board using pca9865 it will have the limitations of all outputs being at the same frequency, which is why navio2, erlebrain2 both use a stm co processor. Funny that raspilot started this trend and then the dev dropped of the face of the earth only to leave me with two paper weight boards. I wish the price was less on this. With shipping etc its not worth it to me. Should have my navio2 by next month hopefully.
