Arducopter 2.0.44
Lots of small tweaks and performance improvements. Here's how testing AP went in the Park:
3689425531?profile=original
3689425580?profile=original
3689425548?profile=original
If you compile with Arduino, you can now set CH7 to trigger some cool things like RTL, or In-Flight leveling.
Check the GIT tree for details on the changes. Most are just nerdy code optimizations.
This release feels very close, if not the last beta. Thanks for all the testing,
Jason
    OK, Fix is posted. I missed that 2 vs 1 thing. It flies fine either way, but it's better and more accurate now.
    Yes, the white lines are the waypoints.
    Jason
    The white lines... are those the waypoints?
  • Currently the value temp in get_angle_boost() is 1.0 when pitch and roll angles are zero. This gets multiplied by 50 and added to the throttle value in Arducopter.pde. I think get_angle_boost() should output zero if the pitch and roll angles are zero. It currently doesn't do that.
    Nonzero values should only be added if pitch and roll angle are nonzero! So basically rewrite the line like this:
    temp = 1.0 - constrain(temp, .5, 1.0);
    Please correct me if my thinking is wrong or if I'm looking at an old code snippet. Thanks!
    How so?
  • Very nice, but I think get_angle_boost() still has the issue we talked about yesterday!
