UPDATE:
Please note that the initialization of Gyros was requested to move to the Arming function. This had the unintended consequence of making the Ground Station report erroneous attitude until the unit is armed at least once. This is changed already in the next version 2.0.39 which is still in development. Thanks.
This is a nice update and is recommended for everyone. I've gotten a half dozen flight in with it and have had good success. I'll be incorporating some of the ideas mentioned in the suggestions post over the next few versions.
What's new:
I reworked the startup so it's much faster. Also, a feature a lot of folks wanted, calibrating the IMU at first Arming is in there. If you hand launch, please do your first arming of the motors on the ground.
I enabled a mode filter for sonar. Not too thoroughly tested performance wise, but it does work. (note, if you rely on the rangefinder class, you must rework your code to be compatible.)
RTL bugs are squashed and it's flying really well now.
Added a special filter in the PID for the derivative term to get rid of the alt hold and loiter issues from noisy sensors.
Added a completely experimental mode called circle. It will by default spin the copter in a 10m circle from the point at which it was engaged. And it will Yaw towards that point at all times.
Yaw while navigating happens at quarter speed, which was problematic before.
Roll and Pitch Imax are higher 5° than before (.5°)
Logging seems to work now. Please erase the log after installing.
Everything else is mentioned on the SVN.
Arm your motors and the apm/IMU will calibrate adjusting the HUD. This is normal with v38 and will be resolved in a next version.
Can you roll .38 back? If so how? I updated and have some esc arming probs and i'm trouble shooting so I'm not saying it's the update- actually I think its my board, its been through hell...When I get the esc's happy the thing flys fine so far...
Level is stored during initial setup with the mission planner or in the field by a special Yaw command. It's not initialized with each flight.
The old way of starting required the copter to be still right after plugging in. The new way allows you to init at first arming of the motors.
Jason
@chris, yes i have mountes my sonar like wiki.
but i have test no sonar, same problem :(
I have a rework station plus I have access to the oven at Nicosia Uni. I could even make the entire board there.
The reason that I want a spare board is to make an experimental one with different gyros. It makes sense to use the parts from the damaged one.
I will however also order a new set from you later today.
1
2
3
4
5
of 8 Next
