Found some good bugs already. An issue with auto trimming being activated due to unusual Radio configurations fixed. Mavlink support is now up to par with APM. and A compass bug in the library squashed.
I revved the firmware's EERPOM fingerprint. You must redo the setup completely. (except ESC calibration.)
Thanks for the feedback!
Jason
You need to pick your kP based on the power of your copter.
the purple engines Jani sells work well with kP of .75 but many kP values would work. kP is not that big of a deal. It's merely how much power you want to go to the engines for rotating. Faster engines might want a lower kP.
I suggest setting this in your AP_Config.h
#define CHANNEL_6_TUNING CH6_STABLIZE_KD
This will let you fly and interactivly change kD.
A low kD value will be very sloppy
A high kD will be very sluggish
A kD that is way too high will oscillate.
There is a test called test_tuning in the CLI that will output the correct value once you've confirmed it flies well.
JasonShall we concentrate on the Stabilize Damp as suggested in the wiki?
It would be nice if you can give us a little tutorial so we can "spread the word" :)
Cheers, and again impressive work!
Emile
Peter
1
2
3
4
of 4 Next
