ArduCopter GoPro 2-Axis Camera-mount
ArduCopter factory is pleased to release first camera mount to famous ArduCopter frames.
This camera-mount fits on all original ArduCopter Quads and Hexas made by jDrones. It has 2 controllable axis that is supported already on ArduCopter software. Miniature ball bearings on all hinge locations. Custom made aluminum nuts to ensure proper mounting of the parts. 2 adjustable push rods with all linkage balls and ball links.
With mount plates this camera mount can be fitted to all Tri, Quad, Hexa and other future frames. On request we can make plates even for other frames.
Weight: 88 gr (includes mount plate and 9g servos)
Servos: 9g-12g (not included)
Frames: Quad, Hexa
Deliveries for these mounts will start on end of 2nd week of November and it can be purchased first from jDrones directly and later on from all jDrones distributors around the world.
Store link: ArduCopter GoPro 2-Axis camera-mount
Don't forget to have correct mount plate to your frame.
You can mount that waterproof case to this mount if you want. We have been flying with this mount and with open camera.. Done few bad crashes too without any damage to the camera itself. But sure if you have safety case around camera it will be even more safer.
Easiest way to mount your GoPro waterproof case is just by adding 2-side tape on the back panel and then stick it on the main camera panel.
Great ! But i will prefer mount where i can put the gopro waterproof case
1
2
3
of 3 Next
